Logging In to Mediation Engine Connector
 You
		must first install an instance of Mediation Engine Connector, connect it to
		your network, and access the user interface using a web browser.
Your browser must have JavaScript enabled. Additionally, allowing "HTTP cookie" is recommended for several of the features.- Point the browser to the configured IP address of the management interface to load the login screen.
 - Log in with your credentials.
