Dependency RPMs
This section describes the RPMs needed to install Session Monitor without an internet connection.
The versions of Dependency RPMs used in this procedure are the latest available versions at the time of this release based on Oracle Linux 8.10 and MySQL 8.0.41 and the RPM file for Session Monitor Release 5.2.0.0.5. Use the latest version of dependency RPMs for all future patche releases based on the Oracle Linux, MySQL and OCSM RPM used.BaseOS Latest:
                  			https://yum.oracle.com/repo/OracleLinux/OL8/baseos/latest/x86_64/index.html
               - keyutils-libs-devel-1.5.10-9.el8.x86_64.rpm
- krb5-devel-1.18.2-26.0.1.el8_9.x86_64.rpm
- libcom_err-devel-1.45.6-5.el8.x86_64.rpm
- libkadm5-1.18.2-26.0.1.el8_9.x86_64.rpm
- libpkgconf-1.4.2-1.el8.x86_64.rpm
- libselinux-devel-2.9-8.el8.x86_64.rpm
- libsepol-devel-2.9-3.el8.x86_64.rpm
- libverto-devel-0.3.2-2.el8.x86_64.rpm
- openssl-devel-1.1.1k-12.el8_9.x86_64.rpm
- openssl-devel-1.1.1k-14.el8_6.x86_64.rpm
- pcre2-devel-10.32-3.el8_6.x86_64.rpm
- pcre2-utf16-10.32-3.el8_6.x86_64.rpm
- pcre2-utf32-10.32-3.el8_6.x86_64.rpm
- perl-Carp-1.42-396.el8.noarch.rpm
- perl-Data-Dumper-2.167-399.el8.x86_64.rpm
- perl-Digest-1.17-395.el8.noarch.rpm
- perl-Digest-MD5-2.55-396.el8.x86_64.rpm
- perl-Encode-2.97-3.el8.x86_64.rpm
- perl-Errno-1.28-422.el8.x86_64.rpm
- perl-Exporter-5.72-396.el8.noarch.rpm
- perl-File-Path-2.15-2.el8.noarch.rpm
- perl-File-Temp-0.230.600-1.el8.noarch.rpm
- perl-Getopt-Long-2.50-4.el8.noarch.rpm
- perl-HTTP-Tiny-0.074-3.el8.noarch.rpm
- perl-IO-1.38-422.el8.x86_64.rpm
- perl-IO-Socket-IP-0.39-5.el8.noarch.rpm
- perl-MIME-Base64-3.15-396.el8.x86_64.rpm
- perl-PathTools-3.74-1.el8.x86_64.rpm
- perl-Pod-Escapes-1.07-395.el8.noarch.rpm
- perl-Pod-Perldoc-3.28-396.el8.noarch.rpm
- perl-Pod-Simple-3.35-395.el8.noarch.rpm
- perl-Pod-Usage-1.69-395.el8.noarch.rpm
- perl-Scalar-List-Utils-1.49-2.el8.x86_64.rpm
- perl-Socket-2.027-3.el8.x86_64.rpm
- perl-Storable-3.11-3.el8.x86_64.rpm
- perl-Term-ANSIColor-4.06-396.el8.noarch.rpm
- perl-Term-Cap-1.17-395.el8.noarch.rpm
- perl-Text-ParseWords-3.30-395.el8.noarch.rpm
- perl-Text-Tabs+Wrap-2013.0523-395.el8.noarch.rpm
- perl-Time-Local-1.280-1.el8.noarch.rpm
- perl-URI-1.73-3.el8.noarch.rpm
- perl-Unicode-Normalize-1.25-396.el8.x86_64.rpm
- perl-constant-1.33-396.el8.noarch.rpm
- perl-interpreter-5.26.3-422.el8.x86_64.rpm
- perl-libnet-3.11-3.el8.noarch.rpm
- perl-libs-5.26.3-422.el8.x86_64.rpm
- perl-macros-5.26.3-422.el8.x86_64.rpm
- perl-parent-0.237-1.el8.noarch.rpm
- perl-podlators-4.11-1.el8.noarch.rpm
- perl-threads-2.21-2.el8.x86_64.rpm
- perl-threads-shared-1.58-2.el8.x86_64.rpm
- pkgconf-1.4.2-1.el8.x86_64.rpm
- pkgconf-m4-1.4.2-1.el8.noarch.rpm
- pkgconf-pkg-config-1.4.2-1.el8.x86_64.rpm
- zlib-devel-1.2.11-25.el8.x86_64.rpm
- tar-1.30-9.el8.x86_64.rpm
- unzip-6.0-46.0.1.el8.x86_64.rpm
- dejavu-fonts-common-2.35-7.el8.noarch.rpm
- dejavu-sans-fonts-2.35-7.el8.noarch.rpm
- dejavu-serif-fonts-2.35-7.el8.noarch.rpm
- fontpackages-filesystem-1.44-22.el8.noarch.rpm
- lm_sensors-libs-3.4.0-23.20180522git70f7e08.el8.x86_64.rpm
- net-tools-2.0-0.52.20160912git.el8.x86_64.rpm
- net-snmp-libs-5.8-30.0.1.el8.x86_64.rpm
- numactl-devel-2.0.16-4.el8.x86_64.rpm
- openssl-perl-1.1.1k-12.el8_9.x86_64.rpm
- openssl-perl-1.1.1k-14.el8_6.x86_64.rpm
- python3-setuptools-39.2.0-7.el8.noarch.rpm
- pciutils-3.7.0-3.el8.x86_64.rpm
- python3-requests-2.20.0-3.el8_8.noarch.rpm
- libicu-60.3-2.el8_1.x86_64.rpm
- python3-chardet-3.0.4-7.el8.noarch.rpm
- python3-idna-2.5-7.el8_10.noarch.rpm
- libmetalink-0.1.3-7.el8.x86_64.rpm
- python3-urllib3-1.24.2-8.el8_10.noarch.rpm
- python3-pysocks-1.6.8-3.el8.noarch.rpm
- yum-utils-4.0.21-25.0.1.el8.noarch.rpm
- openssl-1.1.1k-14.el8_6.x86_64.rpm
- openssl-1.1.1k-12.el8_9.x86_64.rpm
- openssl-libs-1.1.1k-14.el8_6.x86_64.rpm
AppStream Latest:
                  			https://yum.oracle.com/repo/OracleLinux/OL8/appstream/x86_64/index.html
               - perl-IO-Socket-SSL-2.066-4.module+el8.6.0+20623+f0897f98.noarch.rpm
- perl-JSON-2.97.001-2.el8.noarch.rpm
- perl-Memoize-1.03-422.el8.noarch.rpm
- perl-Mozilla-CA-20160104-7.0.1.module+el8.3.0+21136+b437fca9.noarch.rpm
- perl-Net-SSLeay-1.88-2.module+el8.6.0+20623+f0897f98.x86_64.rpm
- perl-Time-HiRes-1.9758-2.el8.x86_64.rpm
- wget-1.19.5-12.0.1.el8_10.x86_64.rpm
- python39-pip-20.2.4-9.module+el8.10.0+90269+2fa22b99.noarch.rpm
- python39-3.9.19-1.module+el8.10.0+90341+71ca88f4.x86_64.rpm
- python39-libs-3.9.19-1.module+el8.10.0+90341+71ca88f4.x86_64.rpm
- python39-pip-wheel-20.2.4-9.module+el8.10.0+90269+2fa22b99.noarch.rpm
- python39-setuptools-wheel-50.3.2-5.module+el8.10.0+90269+2fa22b99.noarch.rpm
- python39-setuptools-50.3.2-5.module+el8.10.0+90269+2fa22b99.noarch.rpm
- fribidi-1.0.4-9.el8.x86_64.rpm
- graphite2-1.3.10-10.el8.x86_64.rpm
- harfbuzz-1.7.5-4.el8.x86_64.rpm
- jbigkit-libs-2.1-14.el8.x86_64.rpm
- lcms2-2.9-2.el8.x86_64.rpm
- libX11-1.6.8-8.el8.x86_64.rpm
- libX11-common-1.6.8-8.el8.noarch.rpm
- libXau-1.0.9-3.el8.x86_64.rpm
- libjpeg-turbo-1.5.3-12.el8.x86_64.rpm
- libsmi-0.4.8-23.el8.x86_64.rpm
- libtiff-4.0.9-32.el8_10.x86_64.rpm
- libwebp-1.0.0-9.el8_9.1.x86_64.rpm
- libxcb-1.13.1-1.el8.x86_64.rpm
- mariadb-connector-c-3.1.11-2.el8_3.x86_64.rpm
- net-snmp-5.8-30.0.1.el8.x86_64.rpm
- net-snmp-agent-libs-5.8-30.0.1.el8.x86_64.rpm
- openjpeg2-2.4.0-5.el8.x86_64.rpm
- python3-pillow-5.1.1-21.el8_10.x86_64.rpm
- python3-reportlab-3.4.0-9.el8.x86_64.rpm
- python39-pyyaml-5.4.1-1.module+el8.9.0+90016+9c2d6573.x86_64.rpm
- sbc-1.3-9.el8.x86_64.rpm
- whois-5.5.1-2.el8.x86_64.rpm
- whois-nls-5.5.1-2.el8.noarch.rpm
- vsftpd-3.0.3-36.el8.x86_64.rpm
- drpm-0.4.1-3.el8.x86_64.rpm
- createrepo_c-0.17.7-6.el8.x86_64.rpm
- createrepo_c-libs-0.17.7-6.el8.x86_64.rpm
- libmaxminddb-1.2.0-10.el8_9.1.x86_64.rpm
Developer EPEL Packages:https://yum.oracle.com/repo/OracleLinux/OL8/developer/EPEL/x86_64/index.html
               - gperftools-libs-2.7-9.el8.x86_64.rpm
- libimagequant-2.12.5-1.el8.x86_64.rpm
- libraqm-0.7.0-4.el8.x86_64.rpm
- libunwind-1.3.1-3.el8.x86_64.rpm
- spandsp-0.0.6-9.el8.x86_64.rpm
- atop-2.7.1-1.el8.x86_64.rpm
Security Validation Packages: https://yum.oracle.com/repo/OracleLinux/OL8/4/security/validation/x86_64/index.html
            - gnutls-3.6.16-8.el8_9.3_fips.x86_64.rpm
- libgcrypt-1.8.5-7.el8_6_fips.x86_64.rpm
