Installing Session Monitor in an Offline Mode - Using the OSDC Website
This chapter describes how to install Session Monitor when the Session Monitor node is without an internet connection.
This procedure was tested on:- Oracle Linux 8.10
- MySQL 8.0.41
- MySQL Connector 8.0.33
You can install Session Monitor in
                an offline mode using any one of the methods listed here:
                  - Method 1: Session Monitor node acts as the repo server.
- Method 2: A separate node acts as the repo server.
The Repo server can be a part of the Session Monitor node itself (Method 1) OR it can be separate node (Method 2). If it is a separate node, the Session Monitor node must be able to reach the Repo server.
In both methods, it is assumed that as Session Monitor node does not have an internet connectivity, so the dependency RPMs and packages would be first downloaded on a machine which has the internet connectivity.
