12 Client-Side Add-Ons
Apps provide an easy way to customize and extend Oracle Communications Operations Monitor with capabilities that are not currently present in the user interface using Javascript and CSS.
You can enable or disable add-ons at login time using the Disable add-ons check box from
the login form. The check box label shows the number of enabled extensions that will be
loaded (unless the check box is selected), and the tooltip shows the name and the
description of each add-on.
Any pre-5.0 customized add-on may not work after upgrading to Session Monitor 5.0. Please consult with Oracle representatives for further support.
