Basics Configuration
The basic configuration for the AWS instance deployment includes:
  1. Get started by completing the tasks outlined in the Launch Instances dialog box.
    • Chose the appropriate region
    • Specify the name as your Virtual machine name
    • Browse all public and private images and search for Oracle Linux 8.10
    • Select the appropriate size of the image, and the minimum recommended shape.
    Figure 9-9 Launch an Instance
    Launch an Instance
