- Installation Guide
- Installing Session Monitor Using the OSDC Website
- Installing Session Monitor in an Offline Mode - Using the OSDC Website
- Tasks to be Performed after Session Monitor Installation - Offline
Perform the tasks provided here, after the RPM installation.
- Run this command to verify the installation is successful:
- Go to the folder
/var/log/ocsmfile. - Verify if the following log file exists: ocsm_installed_*.log
- Go to the folder
- Adjust the firewall to access the Session Monitor applications:
- Run this command to allow the firewall to access the HTTPS service
(port 443):
firewall-cmd --permanent --zone=public --add-service=https
- (Optional) If you are planning to configure the system as a Mediation
Engine, allow the firewall to access the probe connection by doing these
tasks:
- For SBC (embedded) probes:
firewall-cmd --permanent --zone=public --add-port=4739/tcpfirewall-cmd --permanent --zone=public --add-port=4740/tcp - For standalone
probes:
firewall-cmd --permanent --zone=public --add-port=4741/tcpfirewall-cmd --permanent --zone=public --add-port=4742/tcp
The ports 4740 and 4742 are the preferred ports for connecting to SBC / standalone probes respectively. So, the firewall should be opened for ports 4739/4741 only if you are agree to have non-TLS connections. - For SBC (embedded) probes:
(port 443):
- Reload the configuration by running the following command:
firewall-cmd --reloadNote:
If you are planning to enable additional services, see the content about network security in the Oracle Communications Session Monitor Security Guide for a complete list of services and their respective ports. - Enable or Disable SELinux as per your requirement. For more information, see Enabling SELinux - Offline.
