Verifying the Contents of the Session Monitor Installation Bundle
Verify the contents of the Session Monitor installation.zip bundle that you downloaded from the My Oracle Support website (MOS) or Oracle Software Delivery Cloud (OSDC).
Extract the bundle and verify that it has following contents:
- README.txt
 - meta.nfo
 - ocsm-6.0.0.0.0-RPM-GA.zip
 - other_files/
 - other_files/my-8.0.cnf
 - other_files/ocsm-6.0.0.0.0.revision.txt
 - other_files/mysql-shell-commercial-8.4.4-1.1.el8.x86_64.rpm
 - scripts/
 - scripts/Install_OCSM_Rel_6.0.sh
 - scripts/Upgrade_OCSM_Rel_6.0.sh
 - scripts/Backup and Restore Scripts/
 - scripts/Backup and Restore Scripts/MySQLDeltaUpgrade.sh
 - scripts/Backup and Restore Scripts/backupAndRestoreBlockStorage.sh
 - scripts/Backup and Restore Scripts/backupAndRestoreOtherFiles.sh
 - scripts/Offline_Installation/
 - scripts/Offline_Installation/Download_rpms.sh
 - scripts/Offline_Installation/Offline_OCSM_Installation_Rel_6.0.sh
 - scripts/Offline_Installation/Offline_Repo_OCSM_Rel_6.0.sh
 - scripts/Offline_Installation/Offline_Repo_Server_preparation_Rel_6.0.sh
 - scripts/Offline_Installation/Offline_Upgrade_OCSM_Rel_6.0.sh
