Dependency RPMs
This section describes the RPMs needed to install Session Monitor without an internet connection.
The versions of Dependency RPMs used in this procedure are the latest available versions at the time of this release based on:
  • Oracle Linux 9.6
  • MySQL 8.4.6
  • The RPM file for Session Monitor Release 6.1.0.0.0.
Use the latest versions of dependency RPMs for all future patch releases based on the Oracle Linux, MySQL and OCSM RPM used.
BaseOS Latest: https://yum.oracle.com/repo/OracleLinux/OL9/baseos/latest/x86_64/index.html.
  1. pkgconf-m4-1.7.3-10.el9.noarch.rpm
  2. libpkgconf-1.7.3-10.el9.x86_64.rpm
  3. pkgconf-1.7.3-10.el9.x86_64.rpm
  4. pkgconf-pkg-config-1.7.3-10.el9.x86_64.rpm
  5. oracle-epel-release-el9-1.0-1.el9.x86_64.rpm
  6. unzip-6.0-58.0.1.el9_5.x86_64.rpm
  7. dejavu-serif-fonts-2.37-18.el9.noarch.rpm
  8. freetype-2.10.4-10.el9_5.x86_64.rpm
  9. glibc-2.34-168.0.1.el9.x86_64.rpm
  10. libproxy-0.4.15-35.el9.x86_64.rpm
  11. libpciaccess-0.16-7.el9.x86_64.rpm
  12. freetype-2.10.4-10.el9_5.x86_64.rpm
  13. libpng-1.6.37-12.el9.x86_64.rpm
  14. graphite2-1.3.14-9.el9.x86_64.rpm
  15. cups-libs-2.3.3op2-33.el9.x86_64.rpm
  16. avahi-libs-0.8-22.el9_6.x86_64.rpm
  17. glibc-2.34-168.0.1.el9_6.19.x86_64.rpm
  18. glibc-common-2.34-168.0.1.el9_6.19.x86_64.rpm
  19. glibc-gconv-extra-2.34-168.0.1.el9_6.19.x86_64.rpm
  20. glibc-langpack-en-2.34-168.0.1.el9_6.19.x86_64.rpm
  21. harfbuzz-2.7.4-10.el9.x86_64.rpm
AppStream Latest: https://yum.oracle.com/repo/OracleLinux/OL9/appstream/x86_64/index.html
  1. perl-AutoLoader-5.74-481.el9.noarch.rpm
  2. perl-Carp-1.50-460.el9.noarch.rpm
  3. compat-openssl11-1.1.1k-5.el9_6.1.x86_64.rpm
  4. perl-B-1.80-481.el9.x86_64.rpm
  5. perl-Class-Struct-0.66-481.el9.noarch.rpm
  6. perl-Data-Dumper-2.174-462.el9.x86_64.rpm
  7. perl-Digest-1.19-4.el9.noarch.rpm
  8. perl-Digest-MD5-2.58-4.el9.x86_64.rpm
  9. perl-English-1.11-481.el9.noarch.rpm
  10. perl-Errno-1.30-481.el9.x86_64.rpm
  11. perl-Exporter-5.74-461.el9.noarch.rpm
  12. openssl-devel-3.2.2-6.0.1.el9_5.1.x86_64.rpm
  13. perl-Fcntl-1.13-481.el9.x86_64.rpm
  14. perl-File-Basename-2.85-481.el9.noarch.rpm
  15. perl-File-Copy-2.34-481.el9.noarch.rpm
  16. perl-File-Find-1.37-481.el9.noarch.rpm
  17. perl-Encode-3.08-462.el9.x86_64.rpm
  18. perl-File-Path-2.18-4.el9.noarch.rpm
  19. perl-File-Temp-0.231.100-4.el9.noarch.rpm
  20. perl-FileHandle-2.03-481.el9.noarch.rpm
  21. perl-Getopt-Long-2.52-4.el9.noarch.rpm
  22. perl-File-stat-1.09-481.el9.noarch.rpm
  23. perl-Getopt-Std-1.12-481.el9.noarch.rpm
  24. perl-HTTP-Tiny-0.076-462.el9.noarch.rpm
  25. perl-IO-1.43-481.el9.x86_64.rpm
  26. perl-IO-Socket-IP-0.41-5.el9.noarch.rpm
  27. perl-IO-Socket-SSL-2.073-2.el9.noarch.rpm
  28. perl-IPC-Open3-1.21-481.el9.noarch.rpm
  29. perl-MIME-Base64-3.16-4.el9.x86_64.rpm
  30. perl-JSON-4.03-5.el9.noarch.rpm
  31. perl-Math-Complex-1.59-481.el9.noarch.rpm
  32. perl-Memoize-1.03-481.el9.noarch.rpm
  33. perl-Math-BigInt-1.9998.18-460.el9.noarch.rpm
  34. perl-Mozilla-CA-20200520-6.el9.noarch.rpm
  35. perl-NDBM_File-1.15-481.el9.x86_64.rpm
  36. perl-POSIX-1.94-481.el9.x86_64.rpm
  37. perl-Net-SSLeay-1.94-1.el9.x86_64.rpm
  38. perl-PathTools-3.78-461.el9.x86_64.rpm
  39. perl-Pod-Escapes-1.07-460.el9.noarch.rpm
  40. perl-Pod-Perldoc-3.28.01-461.el9.noarch.rpm
  41. perl-Pod-Usage-2.01-4.el9.noarch.rpm
  42. perl-Scalar-List-Utils-1.56-462.el9.x86_64.rpm
  43. perl-Pod-Simple-3.42-4.el9.noarch.rpm
  44. perl-SelectSaver-1.02-481.el9.noarch.rpm
  45. perl-Socket-2.031-4.el9.x86_64.rpm
  46. perl-Storable-3.21-460.el9.x86_64.rpm
  47. perl-Symbol-1.08-481.el9.noarch.rpm
  48. perl-Term-ANSIColor-5.01-461.el9.noarch.rpm
  49. perl-Term-Cap-1.17-460.el9.noarch.rpm
  50. perl-Sys-Hostname-1.23-481.el9.x86_64.rpm
  51. perl-Text-ParseWords-3.30-460.el9.noarch.rpm
  52. perl-Text-Tabs+Wrap-2013.0523-460.el9.noarch.rpm
  53. perl-Time-1.03-481.el9.noarch.rpm
  54. perl-Time-HiRes-1.9764-462.el9.x86_64.rpm
  55. perl-Time-Local-1.300-7.el9.noarch.rpm
  56. perl-URI-5.09-3.el9.noarch.rpm
  57. perl-base-2.27-481.el9.noarch.rpm
  58. perl-constant-1.33-461.el9.noarch.rpm
  59. perl-if-0.60.800-481.el9.noarch.rpm
  60. perl-interpreter-5.32.1-481.el9.x86_64.rpm
  61. perl-libnet-3.13-4.el9.noarch.rpm
  62. perl-mro-1.23-481.el9.x86_64.rpm
  63. perl-overload-1.31-481.el9.noarch.rpm
  64. perl-overloading-0.02-481.el9.noarch.rpm
  65. perl-parent-0.238-460.el9.noarch.rpm
  66. perl-podlators-4.14-460.el9.noarch.rpm
  67. perl-subs-1.03-481.el9.noarch.rpm
  68. perl-libs-5.32.1-481.el9.x86_64.rpm
  69. perl-vars-1.05-481.el9.noarch.rpm
  70. libnsl2-2.0.0-1.el9.x86_64.rpm
  71. python3.11-3.11.11-2.el9.x86_64.rpm
  72. mpdecimal-2.5.1-3.el9.x86_64.rpm
  73. python3.11-setuptools-wheel-65.5.1-3.el9.noarch.rpm
  74. python3.11-pip-wheel-22.3.1-5.el9.noarch.rpm
  75. python3.11-libs-3.11.11-2.el9.x86_64.rpm
  76. python3.11-pip-22.3.1-5.el9.noarch.rpm
  77. python3.11-devel-3.11.11-2.el9.x86_64.rpm
  78. createrepo_c-libs-0.20.1-2.el9.x86_64.rpm
  79. createrepo_c-0.20.1-2.el9.x86_64.rpm
  80. vsftpd-3.0.5-6.el9.x86_64.rpm
  81. python3.11-devel-3.11.11-2.el9.x86_64.rpm
  82. net-snmp-5.9.1-17.0.1.el9.x86_64.rpm
  83. numactl-devel-2.0.19-1.el9.x86_64.rpm
  84. python3.11-pyyaml-6.0-1.el9.x86_64.rpm
  85. openssl-perl-3.2.2-6.0.1.el9_5.1.x86_64.rpm
  86. wireshark-3.4.10-7.el9.x86_64.rpm
  87. whois-5.5.9-4.el9.x86_64.rpm
  88. libX11-1.7.0-11.el9.x86_64.rpm
  89. boost-filesystem-1.75.0-10.el9.x86_64.rpm
  90. boost-program-options-1.75.0-10.el9.x86_64.rpm
  91. boost-system-1.75.0-10.el9.x86_64.rpm
  92. libjpeg-turbo-2.0.90-7.el9.x86_64.rpm
  93. lcms2-2.12-3.el9.x86_64.rpm
  94. openjpeg2-2.4.0-8.el9.x86_64.rpm
  95. libtiff-4.4.0-13.el9.x86_64.rpm
  96. libwebp-1.2.0-8.el9_3.x86_64.rpm
  97. libxcb-1.13.1-9.el9.x86_64.rpm
  98. hicolor-icon-theme-0.17-13.el9.noarch.rpm
  99. qt5-qtbase-5.15.9-10.el9_4.x86_64.rpm
  100. qt5-qtbase-gui-5.15.9-10.el9_4.x86_64.rpm
  101. qt5-qtmultimedia-5.15.9-1.el9.x86_64.rpm
  102. qt5-qtbase-gui-5.15.9-10.el9_4.x86_64.rpm
  103. wireshark-cli-3.4.10-7.el9.x86_64.rpm
  104. xdg-utils-1.1.3-13.el9_6.noarch.rpm
  105. whois-nls-5.5.9-4.el9.noarch.rpm
  106. net-snmp-libs-5.9.1-17.0.1.el9.x86_64.rpm
  107. net-snmp-agent-libs-5.9.1-17.0.1.el9.x86_64.rpm
  108. net-snmp-libs-5.9.1-17.0.1.el9.x86_64.rpm
  109. perl-Term-ReadLine-1.17-481.el9.noarch.rpm
  110. libXau-1.0.9-8.el9.x86_64.rpm
  111. fribidi-1.0.10-6.el9.2.x86_64.rpm
  112. mariadb-connector-c-3.2.6-1.el9_0.x86_64.rpm
  113. lm_sensors-libs-3.6.0-10.el9.x86_64.rpm
  114. libX11-common-1.7.0-11.el9.noarch.rpm
  115. desktop-file-utils-0.26-6.el9.x86_64.rpm
  116. libsmi-0.4.8-30.el9.x86_64.rpm
  117. wget-1.21.1-8.el9_4.x86_64.rpm
  118. libglvnd-glx-1.3.4-1.el9.x86_64.rpm
  119. qt5-qtdeclarative-5.15.9-3.el9.x86_64.rpm
  120. alsa-lib-1.2.13-2.el9.x86_64.rpm
  121. gstreamer1-plugins-base-1.22.12-4.el9.x86_64.rpm
  122. gstreamer1-1.22.12-3.el9.x86_64.rpm
  123. gstreamer1-plugins-bad-free-libs-1.22.12-4.el9_6.x86_64.rpm
  124. openal-soft-1.19.1-16.el9.x86_64.rpm
  125. pulseaudio-libs-15.0-3.el9.x86_64.rpm
  126. libdrm-2.4.123-2.el9.x86_64.rpm
  127. libglvnd-egl-1.3.4-1.el9.x86_64.rpm
  128. libX11-xcb-1.7.0-11.el9.x86_64.rpm
  129. mesa-libgbm-24.2.8-2.el9_6.x86_64.rpm
  130. glx-utils-8.4.0-12.20210504git0f9e7d9.el9.x86_64.rpm
  131. libICE-1.0.10-8.el9.x86_64.rpm
  132. libSM-1.2.3-10.el9.x86_64.rpm
  133. fontconfig-2.14.0-2.el9_1.x86_64.rpm
  134. libinput-1.19.3-5.el9_6.x86_64.rpm
  135. xcb-util-wm-0.4.1-22.el9.x86_64.rpm
  136. xcb-util-image-0.4.0-19.el9.x86_64.rpm
  137. xcb-util-keysyms-0.4.0-17.el9.x86_64.rpm
  138. xcb-util-renderutil-0.3.9-20.el9.x86_64.rpm
  139. libxkbcommon-x11-1.0.3-4.el9.x86_64.rpm
  140. libxkbcommon-1.0.3-4.el9.x86_64.rpm
  141. pcre2-utf16-10.40-6.0.1.el9.x86_64.rpm
  142. qt5-qtbase-common-5.15.9-10.el9_4.noarch.rpm
  143. xcb-util-0.4.0-19.el9.x86_64.rpm
  144. libasyncns-0.8-22.el9.x86_64.rpm
  145. libsndfile-1.0.31-9.el9.x86_64.rpm
  146. mesa-dri-drivers-24.2.8-2.el9_6.x86_64.rpm
  147. libwayland-server-1.21.0-1.el9.x86_64.rpm
  148. xkeyboard-config-2.33-2.el9.noarch.rpm
  149. libevdev-1.11.0-3.el9.x86_64.rpm
  150. mtdev-1.1.5-22.el9.x86_64.rpm
  151. libwacom-1.12.1-3.el9_4.x86_64.rpm
  152. libXext-1.3.4-8.el9.x86_64.rpm
  153. libglvnd-1.3.4-1.el9.x86_64.rpm
  154. mesa-libGL-24.2.8-2.el9_6.x86_64.rpm
  155. mesa-libEGL-24.2.8-2.el9_6.x86_64.rpm
  156. cairo-1.17.4-7.el9.x86_64.rpm
  157. emacs-filesystem-27.2-13.el9_6.noarch.rpm
  158. flac-libs-1.3.3-10.el9_2.1.x86_64.rpm
  159. graphene-1.10.6-2.el9.x86_64.rpm
  160. gsm-1.0.19-6.el9.x86_64.rpm
  161. iso-codes-4.6.0-3.el9.noarch.rpm
  162. libdatrie-0.2.13-4.el9.x86_64.rpm
  163. libogg-1.3.4-6.el9.x86_64.rpm
  164. libthai-0.1.28-8.el9.x86_64.rpm
  165. libtheora-1.1.1-31.el9.x86_64.rpm
  166. libva-2.22.0-1.el9.x86_64.rpm
  167. libvorbis-1.3.7-5.el9.x86_64.rpm
  168. libwacom-data-1.12.1-3.el9_4.noarch.rpm
  169. libwayland-client-1.21.0-1.el9.x86_64.rpm
  170. libwayland-cursor-1.21.0-1.el9.x86_64.rpm
  171. libwayland-egl-1.21.0-1.el9.x86_64.rpm
  172. libXfixes-5.0.3-16.el9.x86_64.rpm
  173. libXft-2.3.3-8.el9.x86_64.rpm
  174. libXi-1.7.10-8.el9.x86_64.rpm
  175. libXrender-0.9.10-16.el9.x86_64.rpm
  176. libxshmfence-1.3-10.el9.x86_64.rpm
  177. libXv-1.0.11-16.el9.x86_64.rpm
  178. libXxf86vm-1.1.4-18.el9.x86_64.rpm
  179. llvm-libs-19.1.7-2.el9.x86_64.rpm
  180. mesa-filesystem-24.2.8-2.el9_6.x86_64.rpm
  181. mesa-libglapi-24.2.8-2.el9_6.x86_64.rpm
  182. mesa-vulkan-drivers-24.2.8-2.el9_6.x86_64.rpm
  183. opus-1.3.1-10.el9.x86_64.rpm
  184. orc-0.4.31-8.el9.x86_64.rpm
  185. pango-1.48.7-3.el9.x86_64.rpm
  186. pixman-0.40.0-6.el9_3.x86_64.rpm
  187. xml-common-0.6.3-58.el9.noarch.rpm
  188. vulkan-loader-1.4.304.0-1.el9.x86_64.rpm
  189. python3.11-setuptools-65.5.1-3.el9.noarch.rpm
  190. jbigkit-libs-2.1-23.el9.x86_64.rpm
  191. urw-base35-bookman-fonts-20200910-6.el9.noarch.rpm
  192. urw-base35-c059-fonts-20200910-6.el9.noarch.rpm
  193. urw-base35-d050000l-fonts-20200910-6.el9.noarch.rpm
  194. urw-base35-fonts-20200910-6.el9.noarch.rpm
  195. urw-base35-fonts-common-20200910-6.el9.noarch.rpm
  196. urw-base35-gothic-fonts-20200910-6.el9.noarch.rpm
  197. urw-base35-nimbus-mono-ps-fonts-20200910-6.el9.noarch.rpm
  198. urw-base35-nimbus-roman-fonts-20200910-6.el9.noarch.rpm
  199. urw-base35-nimbus-sans-fonts-20200910-6.el9.noarch.rpm
  200. urw-base35-p052-fonts-20200910-6.el9.noarch.rpm
  201. urw-base35-standard-symbols-ps-fonts-20200910-6.el9.noarch.rpm
  202. urw-base35-z003-fonts-20200910-6.el9.noarch.rpm
Developer EPEL Packages: https://yum.oracle.com/repo/OracleLinux/OL9/developer/EPEL/x86_64/index.html
  1. libimagequant-2.17.0-1.el9.x86_64.rpm
  2. libraqm-0.8.0-1.el9.x86_64.rpm
  3. unittest-cpp-2.0.0-14.el9.x86_64.rpm
