External Authentication Using RADIUS (via apache httpd)
Follow the typical steps to configure External Authentication Using RADIUS as before and modify the pld.conf. Add the below configuration changes in section '<LocationMatch "^/me/':
    <LocationMatch "^/me/(?!(proxy/|c/|r/|scripts/|/help/|logout\.html)).*$">
        AuthName "OCSM COM"
        AuthType basic
        AuthXRadiusAddServer "RADIUS_IP:RADIUS_PORT" "RADIUS_SHARED_SECRET"
        AuthXRadiusTimeout 5
        AuthXRadiusRetries 3
        AuthBasicProvider xradius
        Require valid-user
        RewriteEngine On
        RewriteCond %{SERVER_PORT} 443
        RewriteCond %{LA-U:REMOTE_USER} (.+)
        RewriteRule .* - [E=RU:%1,L]
        RequestHeader unset X-Forwarded-User
        RequestHeader set X-Forwarded-User %{RU}e
        ProxyPassMatch balancer://mycluster
        ProxyPassReverse  balancer://mycluster
    </LocationMatch>
Replace AuthXRadiusAddServer line as below:
AuthXRadiusAddServer "127.0.0.1:1812" "radsec"
Table 6-4 AuthXRadiusAddServer
Entry Value Remarks
RADIUS_IP 127.0.0.1 Hostname should be local host to internal communication with radsecproxy
RADIUS_PORT 1812 The UDP port on which the radsecproxy server is listening
RADIUS_SHARED_SECRET radsec This field must contain the secret that is shared by Operations Monitor and the RADIUS server used for authentication. The recommended and default will be radsec
AuthXRadiusTimeout 5 Number of seconds to wait response from RADIUS server.
AuthXRadiusRetries 3 Number of retry attempts if a request to the RADIUS server fails
For more information on configuring external RADIUS authentication, see the section Configuring Apache for Authenticating with RADIUS Server in the Oracle Communications Session Monitor Installation Guide Release 6.1Installation Guide.
