Installing and Configuring DPDK Complete the following tasks to install and configure DPDK for Mellanox NIC cards. Create a file /opt/oracle/ocsm/etc/iptego/white_list_dpdk.local with the value mlx5_core before starting the DPDK installation. Log into the Platform Setup Application page. Select Capture Settings. Check the box in the Monitoring column against each sniffing interface that you want to use for capturing the traffic. Log into the machine that hosts the probe or the mediation engine and probe as a root user.(Optional) For better understanding of the network, CPU, and NUMA nodes of the server, run the system_layout.py script to display system information.source /opt/oracle/ocsm/ocsm_env.sh /opt/oracle/ocsm/usr/share/pld/rat/system_layout.py Note:If you observe a Python error while executing the .py files, run the command update-alternatives --config python3 and select the /usr/bin/python3.11 option. Download the DPDK tar file from https://fast.dpdk.org/rel/ into the folder /var/cache/ocsm/dpdk/. Run the following commands as a root user: source /opt/oracle/ocsm/ocsm_env.sh /usr/bin/python3.11 -m pip install meson /usr/bin/python3.11 -m pip install ninja /usr/bin/python3.11 -m pip install pyelftools yum install -y tar yum install gcc-toolset-14.x86_64 Edit /etc/default/grub and set “GRUB_ENABLE_BLSCFG” to False. Once the changes are made in grub, run the command: sudo grub2-mkconfig -o /boot/grub2/grub.cfg Run this command: scl enable gcc-toolset-14 '/opt/oracle/ocsm/usr/share/pld/rat/configure_dpdk_mlx.py' Reboot the machine that hosts the probe or the mediation engine and probe. MLNX drivers require root privileges for the Promiscuous Mode to be enabled. Assign root user privileges to the ocsm user. Open file in edit mode: /etc/passwd Change line ocsm:x:998:996::/opt/oracle/ocsm:/sbin/nologin to ocsm:x:0:0::/opt/oracle/ocsm:/sbin/nologin Restart the RAT service (pld-rat): systemctl restart pld-rat
