Installing Session Monitor using Method 1
Install Session Monitor using Method 1 where the Session Monitor node acts as the Repo server.
  1. Log in to the Session Monitor server installed with Oracle Linux 9.6 as a root user OR root privileged user
  2. Ensure that 5 GB to 10 GB free space is available in the /tmp folder on this server.
  3. If the /tmp/ocsm folder is already present, take a backup of the /tmp/ocsm folder if required and delete the folder /tmp/ocsm.
  4. Create the folder /tmp/ocsm .
    mkdir /tmp/ocsm
  5. Transfer the contents of the folder /tmp/ocsm from the Linux machine, where you have downloaded all the RPM files and scripts - to the /tmp/ocsm folder on the Session Monitor server.
  6. Navigate to the folder /tmp/ocsm on the Session Monitor server.
    cd /tmp/ocsm
  7. Read the following Note
    Caution:
    Complete steps 8 and 10 only, if the software version is 6.1.0.0.0. For other 6.1 patch version, steps 8 and 10 can be skipped.
  8. Install the Kernel version 5.15.0-302.167.6
    1. Install the kernel RPMs in order:
      rpm -ivh kernel-uek-core-5.15.0-302.167.6.el9uek.x86_64.rpm --oldpackage
      rpm -ivh kernel-uek-modules-5.15.0-302.167.6.el9uek.x86_64.rpm --oldpackage
      rpm -ivh kernel-uek-5.15.0-302.167.6.el9uek.x86_64.rpm --oldpackage
    2. Verify the grub configuration and check installed kernel is listed:
      grubby --info=ALL | grep -E "^kernel|^index"
    3. Set the default kernel:
      grubby --set-default=/boot/vmlinuz-5.15.0-302.167.6.el9uek.x86_64
    4. Reboot the system:
      reboot
    5. Verify the kernel version after reboot:
      uname -a
  9. Navigate to the folder /tmp/ocsm on the Session Monitor server:
    cd /tmp/ocsm
  10. Once the VM or Server is up and running with 5.15 kernel, uninstall 6.x kernel and its associated dependencies by executing the following commands
    rpm -qa | grep '^kernel-uek' | grep 6.12
    dnf remove <6.12 kernel packages>
  11. Set execute permission as:
    chmod +x *.sh
  12. Run the following command to install Session Monitor.
    ./Offline_Repo_OCSM_Rel_6.1.sh
