PreviousNext
JavaScript must be enabled to correctly display this content
Installing Session Monitor using Method
1
Install Session Monitor using Method 1
where the Session Monitor node acts as the Repo
server.
Log in to the Session Monitor server
installed with Oracle Linux 9.6 as a root user OR root privileged user
Ensure that 5 GB to 10 GB free space is available in the /tmp
folder on this server.
If the /tmp/ocsm folder is already present, take a backup of
the /tmp/ocsm folder if required and delete the folder
/tmp/ocsm.
Create the folder /tmp/ocsm .
mkdir /tmp/ocsm
Transfer the contents of the folder /tmp/ocsm from the Linux
machine, where you have downloaded all the RPM files and scripts - to the
/tmp/ocsm folder on the Session Monitor server.
Navigate to the folder /tmp/ocsm on the Session Monitor server.
cd /tmp/ocsm
Complete steps 7 and 9 only, if the Session Monitor software version is 6.1.0.0.0. For 6.1 patch version, steps 7 and 9 can be skipped.
