Get Execution by ID
get
/execution/{id}
Retrieves the specified execution.
Request
Path Parameters
Back to Top
Response
Default Response
The default response.
Back to Top
Examples
The following example shows how to retrieve details of an execution by ID by submitting a GET request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X GET "hostname:port/environment/5" -H "accept: */*"
Example of Response Body
If successful, the response code 200 is returned with a response body. For example:
  "_id": 5,
  "name": "update----environment-100",
  "count": 1,
  "connections": [
      "_id": 29,
      "name": "test-update1",
      "properties": [
          "_id": 274923071405041,
          "name": "name--2",
          "value": "value--2"
          "_id": 274923071784208,
          "name": "name--2",
          "value": "value--2"
          "_id": 274923071789083,
          "name": "name--3",
          "value": "value--3"
          "_id": 274923071792791,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071796166,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071799541,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071802875,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071806083,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071809333,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071812541,
          "name": "name--1",
          "value": "value--1"
          "_id": 274923071815625,
          "name": "name--1",
          "value": "value--1"
          "_id": 357844231324209,
          "name": "new-name--1",
          "value": "newvalue"
          "_id": 357844231328042,
          "value": "newvalue"
      "description": "connecction--1-100 description"
  "description": "environment nfVSoxIWbQUgJLH"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
