Create an Execution
post
/execution
Creates an execution.
Request
There are no request parameters for this operation.
Back to Top
Response
Default Response
The default response.
Back to Top
Examples
The following example shows how to create an execution by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
The -d option specifies the file to attach as the request body.
curl -X POST "hostname:port/execution" -H "accept: */*" -H "Content-Type: application/json" -d @file.json
where:
  • file.json is the JSON file the execution details to create.
Example of Request Body
The following is an example of the contents of file.json sent as the request body:
  "job_id": 5,
  "environment_id": 5
Example of Response Body
If successful, the response code 201 is returned along with a header. For example:
  "id": 12
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
