Quick Start
Set up your environment and then use the STAP REST API to make your first API call by performing these tasks:
Prerequisites
| Prerequisite | More Information |
| Install STAP | "Installing STAP" in Deployment Guide |
| Install cURL | Use cURL |
| Set up authentication | Authenticate |
Task 1: Obtain Account Information
From your account administrator, obtain the appropriate account credentials to enable calls to the STAP REST API. If using OAuth authentication, you will need an OAuth 2.0 access token.
Task 2: Send a Request
After you set up your REST client, you can send a request to ensure that your connection works. For example, to retrieve execution by IDs, you can use the following request:
curl -i -H 'Authorization: Bearer accessToken' -X GET
hostname/httpsPort
You can send this request if you want your application to have OAuth support.STAP REST API supports OAuth and Basic Authentication. For more information, see STAP Deployment Guide.
If you do not want your application to have OAuth support, use the following request without the token:
curl -i -X GET hostname/httpsPort/execution/5
If the request is successful, you should receive response code 200 along with a response body similar to the following:
"_id": 5,
"name": "update----environment-100",
"count": 1,
"connections": [
"_id": 29,
"name": "test-update1",
"properties": [
"_id": 274923071405041,
"name": "name--2",
"value": "value--2"
"_id": 274923071784208,
"name": "name--2",
"value": "value--2"
"_id": 274923071789083,
"name": "name--3",
"value": "value--3"
"_id": 274923071792791,
"name": "name--1",
"value": "value--1"
"_id": 274923071796166,
"name": "name--1",
"value": "value--1"
"_id": 274923071799541,
"name": "name--1",
"value": "value--1"
"_id": 274923071802875,
"name": "name--1",
"value": "value--1"
"_id": 274923071806083,
"name": "name--1",
"value": "value--1"
"_id": 274923071809333,
"name": "name--1",
"value": "value--1"
"_id": 274923071812541,
"name": "name--1",
"value": "value--1"
"_id": 274923071815625,
"name": "name--1",
"value": "value--1"
"_id": 357844231324209,
"name": "new-name--1",
"value": "newvalue"
"_id": 357844231328042,
"value": "newvalue"
"description": "connection--1-100 description"
"description": "environment nfVSoxIWbQUgJLH"
