Send Requests
Use these guidelines when sending requests using the STAP REST API.
URL Structure
Here's the URL structure for the requests:
apiRoot/apiType/resourcePathwhere:
- apiRoot is for accessing the HTTP Gateway server at either http://hostname:httpPort or https://hostname:httpsPort.
- apiType is the type of the API:
For user endpoints, use /user.
- resourcePath is the path to the endpoint.
https://hostname:httpsPort/userSupported Methods
You can perform create and read operations on a resource by using standard HTTP/HTTPS method requests, as summarized in the following table.
| HTTP Method | Description |
GET |
Retrieve information about the resource. |
POST |
Create the resource. |
DELETE |
Delete the resource. |
PATCH |
Update a specific part of the resource. |
PUT |
Update the entire resource, replacing the original. |
Media Types
The STAP REST API supports the following media types:
application/json
Supported Headers
The STAP REST API supports the following headers that may be passed in the header section of the HTTP/HTTPS request or response:
| Header | Description | Example |
Authority |
The host name and port number of your Oracle Services Communications Proxy (SCP) Authority Server. Include this header if your system's communication model includes an SCP. |
Authority: example.com:1534 |
Authorization |
The type of authorization. The STAP REST API uses the OAuth 2.0 bearer token framework. |
Authorization: Bearer accessTokenwhere accessToken is your client application's OAuth 2.0/Basic access token. |
Content-Type |
The media type of the request body. This is required for POST and PUT requests. |
Content-Type: application/json |
