Run Automation
post
/taas/runAutomationJob
Runs the automation job.
Request
There are no request parameters for this operation.
Back to Top
Response
Default Response
Sets the default response.
Back to Top
Examples
The following example shows how to run an automation job by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
The -d option specifies the file to attach as the request body.
curl -X POST "hostname:port/runAutomationJob" -H "accept: */*" -H "Content-Type: application/json" -d @file.json
where:
  • file.json is the JSON file with the job details to run.
Example of Request Body
The following is an example of the contents of file.json sent as the request body:
  "name" : "TodoJob",
  "executionConfig" : {
      "name": "Sample Execution Job",
      "execution": "serial",
      "group": [{
          "name": "test",
          "scenarios": [
             "ToDo-E2E-Automation",
              "ToDo-FunctionsAndOperators"
  "environment" : [
          "name" : "todo",
          "type" : "api.rest",
         "hostname"  : "hostname",
          "url" : "URL",
          "authorization" : "YES",
          "authorization.type" : "basic",
          "basic.username" : "firstname.lastname@oracle.com",
          "basic.password" : "password"
  "callBack":{
      "name":"callback",
          "url":"HostNamek",
          "authorize":true,
          "authorization":{
                      "type":"BASIC",
                      "basic": {
                                  "username": "firstname.lastname@oracle.com",
                                  "password": "password"
Example of Response Body
If successful, the response code 200 is returned along with a header. For example:
    "Status": "In-progress",
    "Job-Execution-ID": "TodoJob_1760332645939"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
