Run the AutoTagging process
post
/autotag/run
Request
There are no request parameters for this operation.
Back to Top
Response
200 Response
AutoTagging was completed successfully.
400 Response
Invalid request
Back to Top
Examples
The following example shows how to run an autotagging process by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X POST "hostname:port/autotag/run" -H "accept: */*" -H "Content-Type: application/json" -d @file.json
Example of Response Body
If successful, the response code 201 is returned along with a header. For example:
    "processedRecords": 64,
    "status": "success"
2. SMART SEARCH
http://localhost:8079/search/smartsearch?page=1&limit=10&sortDesc=true&query=control&libraryType=&useSemantic=false
Request Method
GET
response
    "original_query": "control",
    "corrected_query": "",
    "count": 1,
    "results": [
            "date": "2026-03-16T11:05:47",
            "score": 17.640151977539062,
            "data": "{}",
            "name": "Control Structures",
            "resource_id": 12,
            "description": " Control Actions",
            "id": 99,
            "source": "STAP",
            "type": "SCENARIO",
            "auto_tags": "",
            "tags": "E2E, Control Structures"
If the request fails, the response includes the appropriate HTTP code.
Back to Top
