Patch an Execution by ID
patch
/execution/{id}
Partially updates the specified execution.
Request
Path Parameters
Back to Top
Response
Default Response
The default response.
Back to Top
Examples
This example shows how to partially update an execution by ID by submitting a PATCH request on the REST resource using cURL. For more information about cURL, see Use cURL.
curl -X PATCH 'http://hostname:port/execution/1' -d @sampleupdate.json
Example of the Request Body
The following is an example of the contents of the sampleupdate.json file sent as the request body.
      "failureAnalysis": {
        "validation_error": 0,
        "environment_error": 0
      "scenarioResult": [],
      "_id": "6253fef4262ceb61afff2e06",
      "executionId": "6253fef4262ceb61afff2e06",
      "job": "6253f6f2262ceb61afff2dff",
      "name": "ToDo-job",
      "type": "JOB",
      "environmentName": "OVM66",
      "environment": "624e7639262ceb61afff2d1f",
      "build": null,
      "release": null,
      "startTime": 1649671924796,
      "endTime": 1649671924864,
      "status": "PASSED",
      "total": 0,
      "completed": 0,
      "passed": 0,
      "failed": 0,
      "error": 0,
      "skipped": 0,
      "__v": 0
Example of the Response Body
If successful, the response code 201 is returned with the following response body.
    "status": "SUCCESS",
    "count": 0
Back to Top
