Perform SmartSearch with filters
post
/search/smartsearch
Request
Query Parameters
Back to Top
Response
200 Response
SmartSearch results
400 Response
Invalid request
Back to Top
Examples
The following example shows how to perform smart search with filters by submitting a POST request on the REST resource using cURL. For more information about cURL, see "Use cURL".
The -d option specifies the file to attach as the request body.
curl -X POST "hostname:port/search/smartsearch?page=1&limit=10&sortDesc=true&query=control&libraryType=&useSemantic=false" -H "accept: */*" -H "Content-Type: application/json" -d @file.json
Example of the Request Body
The following is an example of the contents of the sampleUpdatePassword.json file sent as the request body.
Example Value
Schema
  "query": "Account",
  "libraryType": "STEP",
  "useSemantic": false
Example of Response Body
If successful, the response code 201 is returned along with a header. For example:
    "original_query": "control",
    "corrected_query": "",
    "count": 1,
    "results": [
            "date": "2026-03-16T11:05:47",
            "score": 17.640151977539062,
            "data": "{}",
            "name": "Control Structures",
            "resource_id": 12,
            "description": " Control Actions",
            "id": 99,
            "source": "STAP",
            "type": "SCENARIO",
            "auto_tags": "",
            "tags": "E2E, Control Structures"
If the request fails, the response includes the appropriate HTTP code.
Back to Top
