Get Job Status by ID
get
/taas/job/{executionID}
Retrieves the given job's status.
Request
Path Parameters
Back to Top
Response
200 Response
The job status was successfully found.
404 Response
The job was not found.
Back to Top
Examples
The following example shows how to retrieve a job's status by ID by submitting a GET request on the REST resource using cURL. For more information about cURL, see "Use cURL".
curl -X GET "hostname:port/taas/job/25" -H "accept: */*"
Example of Response Body
If successful, the response code 200 is returned with a response body. For example:
"25":"In-progress"
If the request fails, the response includes the appropriate HTTP code. For a 4xx/5xx code, the message body also contains a ProblemDetails structure with the cause attribute set to the appropriate application error.
Back to Top
