- Essentials Guide
- Subscriber-Aware Load Balancer Configuration
- SLB Configuration
- Load Balancer Policy Configuration
The lbp-config configuration element manages the SLB endpoint table. It also creates and manages a list of service interfaces (signaling addresses) that are advertised to endpoints comprising the user access population.
Use the following procedure to perform required lbp-config configuration.
- From superuser
mode, use the following ACLI command sequence to access lbp-config
configuration mode. While in this mode, you configure the lbp-config
configuration element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# lbp-config ORACLE(lbp-config)#? state lbp state log-level configure log level untrusted-grace-period Untrusted grace period max-untrusted-percentage Maximum untrusted endpoints percentage max-untrusted-upper-threshold Maximum untrusted endpoints upper threshold max-untrusted-lower-threshold Maximum untrusted endpoints upper threshold endpoint-capacity-upper-threshold endpoint capacity upper threshold endpoint-capacity-lower-threshold endpoint capacity lower threshold red-port lbp redundant sync port: 0 to disable and 2000 to enable red-max-trans maximum redundancy transactions to keep on active red-sync-start-time timeout for transitioning from standby to active red-sync-comp-time sync request timeout after initial sync completion port-aware-balancing Include endpoint source port, in addition to the source IP address if NAT is used options optional features/parameters strategy Configure the balancing strategy select select lbp config no delete lbp config show show lbp config done save lbp config information exit return to previous menu ORACLE(lbp-config)# - Use the
state parameter to
enable or disable the
SLB software.
The default setting, enabled, enables SLB functionality; disabled renders the SLB inoperable.
ORACLE(lbp-config)# state enabled ORACLE(lbp-config)# - Use the
log-level parameter
to specify the contents of the SLB log.
Log messages are listed below in descending order of severity.
- emergency — the most severe
- critical
- major (error)
- minor (error)
- warning
- notice
- info — (default) the least severe
- trace — (test/debug, not used in production environments)
- debug — (test/debug, not used in production environments)
- detail — (test/debug, not used in production environments)
In the absence of an explicitly configured value, log-level defaults to critical, meaning that log messages with a severity of critical or greater (emergency) are written to the LBP log.
ORACLE(lbp-config)# log-level critical ORACLE(lbp-config)# - Use the
parameter to specify the maximum time, in seconds, that
a forwarding rule is retained by the
SLB before it is
confirmed with a promotion message from the OCSBC that received the untrusted
endpoint. Refer to the Balancing section for message details
In the absence of an explicitly assigned value, the SLB provides a default setting of 32 (seconds). If this time period elapses without a promotion message arriving to confirm this user, the SLB deletes the entry.
Setting this parameter to 0 allows untrusted/unconfirmed entries to exist indefinitely without aging out.
ORACLE(lbp-config)# untrusted-grace-period 32 - Use the
parameter to specify the percentage of the overall endpoint population that is
reserved for untrusted users.
The default setting is 20 (percent); supported values are integers within the range 1 through 100.
This percentage is applied to the overall remaining occupancy of the SLB after trusted (confirmed) users are accounted for. For example, when empty, the SLB holds two million forwarding rules; assuming the default setting, at most 400,000 rules are reserved for untrusted rules. By the time one million users have been promoted, 20% of the remaining space means that up to 200,000 entries can be used for untrusted users.
ORACLE(lbp-config)# max-untrusted-percentage 20 - Use the
parameter to specify a threshold level at which the
SLB (1) raises an
alarm, and (2) issues an SNMP trap reporting an excessive number of untrusted
endpoints within the entire endpoint population.
This parameter, which has a default setting of 80 (percent), is calculated as a percent of max-untrusted-percentage. For example, assuming default settings for both parameters, the SLB raises an alarm and issues an SNMP trap when the percentage of untrusted endpoints attains 16%.
ORACLE(lbp-config)# max-untrusted-upper-threshold 80 - Use the
SLB (1) clears the
existing untrusted endpoint alarm, and (2) issues an SNMP trap reporting alarm
clearance.
This parameter, which has a default setting of 70 (percent), is calculated as a percent of max-untrusted-percentage. For example, assuming default settings for both parameters, the SLB clears an alarm and issues an SNMP trap when the percentage of untrusted endpoints falls to 14%.
ORACLE(lbp-config)# max-untrusted-lower-threshold 70 - Use the
and
parameters to implement license-based management and monitoring of the
SLB endpoint counts.
endpoint-capacity-upper-threshold specifies a threshold level at which the SLB (1) raises an alarm, and (2) issues an SNMP trap reporting an excessive number of active endpoints.
This parameter, which has a default setting of 80 (percent), is calculated as a percentage of the endpoints allowed by the installed SLB license.
endpoint-capacity-lower-threshold specifies a threshold level at which the SLB (1) clears the existing endpoint alarm, and (2) issues an SNMP trap reporting alarm clearance.
This parameter, which has a default setting of 70 (percent), is calculated as a percentage of the endpoints allowed by the installed SLB license.
ORACLE(lbp-config)# endpoint-capacity-upper-threshold 80 ORACLE(lbp-config)# endpoint-capacity-lower-threshold 70 ORACLE(lbp-config)# - Enable
to include endpoint source port, in addition to the source IP and destination
service representation when looking up a unique EPT prior to forwarding towards
the OCSBC cluster. Choices are enabled and disabled. Default is disabled.
Reboot all SLBs and OCSBCs when enabling or disabling this parameter.
ORACLE(lbp-config)# port-aware-balancing enabled ORACLE(lbp-config)#
WARNING:
- Set your preferred
strategy to
determine how the
SLB distributes new
end-points to the OCSBCs. Choices include capacity-proportional and
least-occupied. The default is least-occupied.
ORACLE(lbp-config)# strategy least-occupied ORACLE(lbp-config)# - Use
done,
exit, and
verify-config to
complete configuration of this load-balancer-policy configuration element.
