Known Issues for Release S-Cz9.3.0
The Known Issues below apply to release S-Cz9.3.0 of the Subscriber Aware Load Balancer (SLB). For Known Issues on products that are Subscriber-Aware Load Balancer (SLB) cluster members, refer to the Oracle Communications Session Border Controllers (OCSBC) product's Release Notes.
| ID | Description | Severity | Found In | |
| N/A | When populated
with 10 million registrations or more, the SLB may not synchronize all
registrations before the default
redundancy-config's
becoming-standby-time
timeout of 180000.
Workaround: Set the SLB's becoming-standby-time timeout to 1800000 when handling 10 million registrations or more. |
N/A | S-Cz7.3.10 | |
| N/A | The Oracle Communications Session Border Controller does not support overlapping IP addresses on Media interfaces between end points and SBCs in deployments that use an Oracle Communications Subscriber Aware Load Balancer for load balancing. | N/A | S-Cz7.3.10 | |
Resolved Known Issues
The following table provides a list of previous Known Issues that are
now resolved.
| ID | Description | Severity | Found In | Fixed In | |
22066052 |
During a HA failover, IPT core miss errors are incremented, which results in retransmissions. | 3 | S-Cz7.2.10p3 | S-Cz9.3.0 | |
20577310 |
When approaching the maximum supported registrations per second, the user may find that only a small percentage of endpoint registrations correctly expire and must re-register. | 4 | S-Cz7.2.10 | S-Cz9.3.0 | |
26050436 25814014 |
When an SLB is operating in HA mode, the standby periodically sends SYNC messages to the Active. If, for any reason, the Active's response is delayed, the standby resends these SYNCs. If this "resend" happens after the active has responded, the active writes a "Stray response" log message to the log.lbp file. This issue may confuse the user, but does not impact service. | 4 | S-Cz7.3.10 | S-Cz9.0.0 | |
| The capacity-proportional balancing strategy, introduced as a new feature in the OCSLB is not documented in the SLB Essentials Guide. | 4 | S-Cz8.3.0m1 | S-Cz8.3.0m1p1 | ||
