Related Documentation
For more information, see the following documents in the Oracle Communications Unified Inventory Management Release documentation set:
UIM Concepts: Provides an overview of important concepts and an introduction to using both UIM and Design Studio.
UIM Installation Guide: Describes the requirements for installing UIM, installation procedures, and post-installation tasks.
UIM System Administrator's Guide: Describes administrative tasks such as working with cartridges and cartridge packs, maintaining security, managing the database, configuring Oracle Map Viewer, and troubleshooting.
UIM Security Guide: Provides guidelines and recommendations for setting up UIM in a secure configuration.
UIM Developer's Guide: Explains how to customize and extend many aspects of UIM, including the data model, life-cycle management, topology, security, rulesets, user interface, and localization.
UIM Web Services Developer's Guide: Describes the UIM Service Fulfillment Web Service operations and how to use them, and describes how to create custom web services.
UIM API Overview: Provides detailed information and code examples of numerous APIs presented within the context of a generic service fulfillment scenario, and within the context of a channelized connectivity enablement scenario.
UIM Information Model Reference: Describes the UIM information model entities and data attributes, and explains patterns that are common across all entities. This document is available on the Oracle Software Delivery Cloud as part of the Oracle Communications Unified Inventory Management Developer Documentation package.
Oracle Communications Information Model Reference: Describes the Oracle Communications information model entities and data attributes, and explains patterns that are common across all entities. The information described in this reference is common across all Oracle Communications products. This document is available on the Oracle Software Delivery Cloud as part of the Oracle Communications Unified Inventory Management Developer Documentation package.
UIM Cartridge Guide: Provides information about how you use cartridges and cartridge packs with UIM. Describes the content of the base cartridges.
For step-by-step instructions for performing tasks, log in to each application to see the following:
Design Studio Help: Provides step-by-step instructions for tasks you perform in Design Studio.
UIM Help: Provides step-by-step instructions for tasks you perform in UIM.
