Retrieve an existing Edge based on typeId and referenceId
get
/topology/v2/edge/typeid/{typeid}/referenceid/{referenceid}
Request
Path Parameters
referenceid(required): string
The referenceId of the edge
typeid(required): string
The typeId of the edge
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
Edge retrieved successfully
Root Schema : schema
Type:
Show Source
object-
autoSuggestName: string
availableCapacity: boolean
businessObjectClass: string
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
createdUser: string
edgeType: string
entityId: integer
(int64)
entityVersion: integer
(int32)
fromNode: integer
(int64)
fromNodeBusinessObjectClass: string
fromNodeData: string
fromNodeReferenceId: string
inventoryStatus: string
isChannelized: boolean
isPipeInterfaceTerminated: boolean
lastModifiedDate: string
(date)
lastModifiedUser: string
maxBandwidth: number
maxContiguousChannels: integer
(int32)
pathIds: array
pathIds
Unique Items Required:
true -
properties: object
properties
Additional Properties Allowed: additionalProperties
protectedEdge: boolean
ratecode: string
referenceId: integer
(int64)
specName: string
technology: string
toNode: integer
(int64)
toNodeBusinessObjectClass: string
toNodeData: string
toNodeReferenceId: string
totalCapacity: number
trailPaths: integer
(int32)
unitBitRate: number
Examples
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
