Retrieve a list of containment edges
get
/topology/v2/edge/containment
Retrieve a list of comtainment edges.
Request
Query Parameters
edgeLabel: string
The edge label for the edges. Refer Valid Values section of Active Topology Automator Model Documentation for the list of values of EdgeLabel.
fromnode: string
The fromnode entityid for the edges.
fromnodeId: string
The fromNode id of the edges.
fromnodeLabel: string
The fromnode label for the edges.
tonode: string
The tonode label for the edges.
tonodeId: string
The toNode id of the edges.
tonodeLabel: string
The toNode label for the edges.
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
Edges retrieved successfully.
Root Schema : schema
Type:
Show Source
object-
autoSuggestName: string
availableCapacity: boolean
businessObjectClass: string
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
edgeType: string
entityId: integer
(int64)
entityVersion: integer
(int32)
fromNode: integer
(int64)
fromNodeBusinessObjectClass: string
fromNodeData: string
fromNodeReferenceId: string
inventoryStatus: string
isChannelized: boolean
isPipeInterfaceTerminated: boolean
lastModifiedDate: string
(date)
Example:
2022-03-10 -
lastModifiedUser: string
maxBandwidth: number
maxContiguousChannels: integer
(int32)
pathIds: array
pathIds
Unique Items Required:
true -
properties: object
properties
Additional Properties Allowed: additionalProperties
protectedEdge: boolean
ratecode: string
referenceId: integer
(int64)
specName: string
technology: string
toNode: integer
(int64)
toNodeBusinessObjectClass: string
toNodeData: string
toNodeReferenceId: string
totalCapacity: number
trailPaths: integer
(int32)
unitBitRate: number
Examples
400 Response
The request isn't valid.
401 Response
The request is unauthorized.
403 Response
The request is forbidden.
404 Response
The requested resource not found.
500 Response
An Internal Server Error has occurred.
