Fetch Pipe/Connectivity Channels
get
/topology/v2/tmf/resourceadapter/edge/paths/underlay/channels/{id}
Fetch Pipe/Connectivity Channels.
Request
Path Parameters
Query Parameters
There's no request body for this operation.
Back to Top
Response
Supported Media Types
200 Response
List of channels retrieved successfully.
Body ()
Root Schema : schema
Type: array
Show Source
Examples
400 Response
The request isn't valid
Body ()
Root Schema : ErrorType
Type: object
Show Source
Nested Schema : message
Type: array
Show Source
401 Response
The request is unauthorized
Body ()
Type: object
Show Source
Type: array
Show Source
403 Response
The request is forbidden
Body ()
Type: object
Show Source
Type: array
Show Source
404 Response
The requested resource not found
Body ()
Type: object
Show Source
Type: array
Show Source
500 Response
An Internal Server Error has occurred
Body ()
Type: object
Show Source
Type: array
Show Source
Back to Top
