Retrieve a list of communication edges terminated on a network entity code
get
/topology/v2/edge/communication/nec/eid/{neceid}
Request
Path Parameters
Query Parameters
There's no request body for this operation.
Back to Top
Response
Supported Media Types
200 Response
Edges retrieved successfully
Body ()
Root Schema : GraphData
Type: object
Show Source
Nested Schema : AlarmSummary
Type: object
Show Source
Nested Schema : edges
Type: array
Show Source
Nested Schema : filterChips
Type: array
Show Source
Nested Schema : filters
Type: array
Show Source
Nested Schema : nodes
Type: array
Show Source
Nested Schema : schema
Type: object
Show Source
Nested Schema : capacities
Type: array
Show Source
Nested Schema : channels
Type: array
Show Source
Nested Schema : pathIds
Type: array
Unique Items Required: true
Show Source
Nested Schema : properties
Type: object
Additional Properties Allowed
Show Source
Nested Schema : Capacity
Type: object
Show Source
Nested Schema : FilterChip
Type: object
Show Source
Nested Schema : dependencies
Type: array
Show Source
Type: object
Show Source
Nested Schema : Vertex
Type: object
Show Source
Nested Schema : bridgeEdges
Type: array
Show Source
Type: array
Show Source
Type: object
Show Source
Nested Schema : relationships
Type: object
Show Source
Nested Schema : BridgeEdge
Type: object
Show Source
Examples
400 Response
The request isn't valid
Body ()
Root Schema : ErrorType
Type: object
Show Source
Nested Schema : message
Type: array
Show Source
401 Response
The request is unauthorized
Body ()
Type: object
Show Source
Type: array
Show Source
403 Response
The request is forbidden
Body ()
Type: object
Show Source
Type: array
Show Source
404 Response
The requested resource not found
Body ()
Type: object
Show Source
Type: array
Show Source
500 Response
An Internal Server Error has occurred
Body ()
Type: object
Show Source
Type: array
Show Source
Back to Top
