Fetch GraphData based on entityType and entityid.
get
/topology/v2/tmf/resourceadapter/edge/paths/{entityType}/{eid}
Request
Path Parameters
eid(required): string
Topology entity id of the Pipe or Connectivity.Example:
573739 -
entityType(required): string
"pipe" and "connectivity" are the only valid values.
Query Parameters
isChannel: boolean
When this is true, ATA DB will not be looked up for the eid and the eid should be the actual Inventory ID of the channel.
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
JSON response after retrieveing the GraphData
Nested Schema : schema
Type:
Show Source
object-
autoSuggestName: string
availableCapacity: boolean
businessObjectClass: string
capacities: array
capacities
channels: array
channels
costValue1: number
(double)
costValue2: number
(double)
costValue3: number
(double)
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
edgeType: string
entityId: integer
(int64)
entityVersion: integer
(int32)
fromNode: integer
(int64)
fromNodeBusinessObjectClass: string
fromNodeCapacityConsumed: number
(float)
fromNodeData: string
fromNodeId: string
fromNodeReferenceId: string
inventoryStatus: string
isChannelized: boolean
isPipeInterfaceTerminated: boolean
lastModifiedDate: string
(date)
Example:
2022-03-10 -
lastModifiedUser: string
maxBandwidth: number
maxContiguousChannels: integer
(int32)
nativeEMSName: string
pathIds: array
pathIds
Unique Items Required:
true -
plannedActiveEvent: integer
(int64)
properties: object
properties
Additional Properties Allowed: additionalProperties
protectedEdge: boolean
ratecode: string
referenceId: integer
(int64)
ringName: string
specName: string
technology: string
toNode: integer
(int64)
toNodeBusinessObjectClass: string
toNodeCapacityConsumed: number
(float)
toNodeData: string
toNodeId: string
toNodeReferenceId: string
totalCapacity: number
trailPaths: integer
(int32)
unitBitRate: number
unplannedActiveEvent: integer
(int64)
Nested Schema : FilterChip
Type:
Show Source
object-
filter: string
Name of the smart search filter.
value:
value
Filter value. Send one scalar value for a single selection or an array of values for a multi-select filter.
Nested Schema : value
Match One Schema
Show Source
Nested Schema : Vertex
Type:
Show Source
object-
activeEventDesc: string
area: string
availablePositions: string
bridgeEdges: array
bridgeEdges
true -
capacityConsumed: number
(float)
category: string
circle: string
city: string
communication: integer
(int64)
country: string
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
deviceIdentifier: string
deviceInterfaceId: string
deviceInterfaceName: string
district: string
entityId: integer
(int64)
(int32)
equipmentCategory: string
fromNodeSubNetwork: integer
(int64)
ipv4: string
ipv4Subnet: string
ipv6: string
ipv6Subnet: string
(date)
Example:
2022-03-10 -
latitude: number
(double)
layerId: integer
(int32)
layerName: string
locationCode: string
locationName: string
longitude: number
(double)
macAddress: string
networkStatus: string
nodeCategory: string
nodeType: string
occupiedPositions: string
operator: string
pathIds: array
pathIds
true -
physicalPortId: string
physicalPortName: string
(int64)
postalCode: string
properties: object
properties
province: string
(int64)
region: string
relationships: object
relationships
specName: string
state: string
subCategory: string
subNetworkEntityId: integer
(int64)
subNetworkId: integer
(int64)
subNetworkName: string
subType: string
toNodeSubNetwork: integer
(int64)
topologyType: string
(int64)
zoneId: string
Examples
