Update the Active Event Max Severity for the device
put
/topology/v2/vertex/activeEvent/eid/{eid}/severity/{severity}
DEPRECATED: Use /alarms/aggregate/event-update to maintain alarm counts. This endpoint only updates the legacy max severity on the device.
Request
Path Parameters
eid(required): string
The entity id of the device vertex
severity(required): string
The severity value for all active events
Query Parameters
There's no request body for this operation.
Back to TopResponse
Supported Media Types
- application/json
200 Response
Vertex patched successfully
Root Schema : schema
Type:
Show Source
object-
activeEventDesc: string
area: string
autoSuggestName: string
availablePositions: string
bridgeEdges: array
bridgeEdges
Unique Items Required:
true -
businessObjectClass: string
capacityConsumed: number
(float)
category: string
circle: string
city: string
communication: integer
(int64)
country: string
createdDate: string
(date)
Example:
2022-03-10 -
createdUser: string
deviceIdentifier: string
deviceInterfaceId: string
deviceInterfaceName: string
district: string
entityId: integer
(int64)
entityVersion: integer
(int32)
equipmentCategory: string
fromNodeSubNetwork: integer
(int64)
inventoryStatus: string
ipv4: string
ipv4Subnet: string
ipv6: string
ipv6Subnet: string
lastModifiedDate: string
(date)
Example:
2022-03-10 -
lastModifiedUser: string
latitude: number
(double)
layerId: integer
(int32)
layerName: string
locationCode: string
locationName: string
longitude: number
(double)
macAddress: string
nativeEMSName: string
networkStatus: string
nodeCategory: string
nodeType: string
occupiedPositions: string
operator: string
pathIds: array
pathIds
true -
physicalPortId: string
physicalPortName: string
plannedActiveEvent: integer
(int64)
postalCode: string
properties: object
properties
Additional Properties Allowed: additionalProperties
province: string
referenceId: integer
(int64)
region: string
relationships: object
relationships
specName: string
state: string
subCategory: string
subNetworkEntityId: integer
(int64)
subNetworkId: integer
(int64)
subNetworkName: string
subType: string
toNodeSubNetwork: integer
(int64)
topologyType: string
unplannedActiveEvent: integer
(int64)
zoneId: string
Examples
400 Response
The request isn't valid
401 Response
The request is unauthorized
403 Response
The request is forbidden
404 Response
The requested resource not found
500 Response
An Internal Server Error has occurred
