Broker Control
The Broker Control UIs are used to interface with the Unified Assurance Broker Daemon/Service, sending control signals for services and jobs on the different Unified Assurance servers.
The following list gives you the names of the six Broker Control UIs and a brief description of their respective functions:
Broker Configurations
This section focuses on some of the more advanced configurations that can be made from the Broker Control UI, including the following:
Creating a New Service
An application's configuration will control certain aspects of the application's behavior in Unified Assurance. In certain cases, it makes sense to run the same application multiple times with different settings. In this example, you will create a new Ping Latency Poller service that will poll devices in a Device Zone that is different to the standard Ping Latency Poller.
  1. Navigate to Device Zones UI and create a new Device Zone titled WAN.
    Configuration -> Device Catalog -> Device Zones
  2. Navigate to Device Management UI and move a few devices to the WAN Device Zone.
    Configuration -> Device Catalog -> Device Management
  3. Go to the Services UI.
    Configuration -> Broker Control -> Services
  4. Click to select the existing Metric Ping Latency Poller service, and click the Clone button to clone the service.
  5. In the form (to the right of the grid), enter an appropriate name for the Service Name and for the Log File configuration type.
    1. For example, WAN Metric Ping Latency Poller and logs/MetricWANPingPoller.log, respectively.
  6. Select WAN for the DeviceZoneID.
    New application configuration types can be added and edited from the Application Config Types UI.
    Configuration -> Broker Control -> Application Config Types
  7. Click Submit to save the new service.
  8. Start the new WAN Metric Ping Latency Poller service. It now polls metrics for the Devices in Zone WAN.
Servers
The Servers UI is used for viewing the broker configuration options of an Unified Assurance server.
Configuration -> Broker Control -> Servers
Selecting a server from this interface will open the Server (edit) form to the right of the grid. From this form, various Broker configuration options can be edited, such as:
