Broker Control UIs
The Broker Control UIs are used to interface with the Unified Assurance Broker Daemon/Service, sending control signals for services and jobs on the different Unified Assurance servers.
The following list gives you the names of the six Broker Control UIs and a brief description of their respective functions:
Broker Configurations
This section focuses on some of the more advanced configurations that can be made from the Broker Control UIs, including the following:
Creating a New Service
An application's configuration will control certain aspects of the application's behavior in Unified Assurance. In certain cases, it makes sense to run the same application multiple times with different settings. In this example, you will create a new Ping Latency Poller service that will poll devices in a Device Zone that is different to the standard Ping Latency Poller.
  1. Go to the Device Zones UI and create a new Device Zone titled WAN.
    To open the Device Zones interface, from the main navigation menu, select Configuration, then Device Catalog, and then Device Zones.
  2. Go to the Device Management UI, and use the Move Device to Zone action type to move a few devices to the WAN Device Zone.
    To open the Device Management interface, from the main navigation menu, select Configuration, then Device Catalog, and then Device Management.
  3. Go to the Services UI:
    From the main navigation menu, select Configuration, then Broker Control, and then Services.
  4. Select the default Metric Ping Latency Poller service, and click the Clone button to clone the service.
  5. In the form (to the right of the grid), enter an appropriate name for the service Name and for the LogFile configuration.
    For example, use WAN Metric Ping Latency Poller and logs/MetricWANPingPoller.log, respectively.
  6. In the configuration section, change DeviceZoneID and select WAN.
    New application configuration types can be added and edited from the Application Config Types UI.
    To open the Application Config Types interface, from the main navigation menu, select Configuration, then Broker Control, and then Application Config Types.
  7. Click Submit to save the new service.
  8. Start the new WAN Metric Ping Latency Poller service. It now polls metrics for the Devices in Zone WAN.
Servers
The Servers UI is used for viewing the broker configuration options of a Unified Assurance server.
To open the Servers interface, from the main navigation menu, select Configuration, then Broker Control, and then Servers.
Selecting a server from this interface will open the Server (edit) form to the right of the grid. From this form, various Broker configuration options can be edited, such as:
