Multi-Group Users
Learn about controlling access to Oracle Communications Unified Assurance user interfaces by assigning users to multiple groups.
About Multi-Group Users
A multi-group user is a user assigned to multiple user groups. Multi-group users have access to everything available in each group. This allows for a hierarchy of user access. You can restrict data using the restrictive user group properties. Assigning a user to multiple groups allows them to combine those restrictive groups without the need to log out and back in as different users.
Choosing Multi-Group Users or Multitenancy
Multi-group users and multitenancy serve different purposes. Multitenancy allows data to be viewed without regard to the restrictions of users and groups. If a user does not need access to typical configuration processes, but does need to view a specific service or dashboard, choose multitenancy. If a user provides support for two separate user groups and needs to be able to access everything those users can, choose multi-group users.
See Configuring Multitenancy for more information about multitenancy.
Setting Up Multi-Group Users
To set up multi-group users:
  1. Create content for each group.
    1. Make sure devices are discovered and data is being collected.
    2. Create any required dashboards.
      Even if a user has access to the dashboard, the content within the dashboard, such as devices, is still checked for access.
    3. Create any required diagrams.
      Even if a user has access to the diagram, the content within the diagram, such as devices, is still checked for access.
    4. Create any required event filters.
    5. Create any required links.
    6. Create any required menus for the desired areas: diagrams, events, and topology. If a user has access to multiple menus, the menu options will be combined into a single menu with any duplicates removed.
  2. Create groups for the desired areas: dashboard groups, device groups, diagram groups, event filter groups, and link groups. These groups will determine what each user has access to.
  3. Create user groups with the proper restrictive properties set. The absence of a restrictive property will generally result in Root-level or Global-level access. The following exceptions exist:
    • RestrictiveEventMenuID: If no restriction is set, the user group will have access to whichever menu is flagged as the default menu.
    • RestrictiveTopologyMenuID: If no restriction is set, the user group will have access to the Default Topology Tools menu.
    • RestrictiveDiagramMenuID: By default, diagrams do not have context menus. A widget in a diagram only has a context menu if you select one in the widget editor under Action.
      If no restriction is set, the user group will have access to the Root context menu in the widget editor or when viewing the final diagram, if any context menus have been selected for the diagram.
  4. Create or update users to have the appropriate user group or groups. The users form has a User Group Name field for the primary group. If the user needs access to additional groups, they are added through the Subgroups selector.
    Preferences for a user are only inherited from the primary user group.
    Preferences that are set for a user subgroup are not inherited to the user.
Context Menus with Multi-Group Users and Restrictive Menus Access
The access to context menus and which menu items appear for multi-group users depends on the type of menu. Event and topology menus behave in the same way, and diagram menus differ.
Event and Topology Menus
The tools and submenus available in event and topology menus are made up of items from the restrictive menus set for the primary user group and subgroups. If no restrictive menus are set:
A separator divides menu items from the primary user group and subgroups. The items from the primary user group are sorted according to the order configured in the menu. The items from subgroups are sorted alphabetically.
If an item from a subgroup already appears at the same level for the primary group or another subgroup, it is not repeated. Each menu or tool will only appear once at each level. However, if an item appears in two different menus, both of which are nested under the same parent menu, the item will appear twice: once inside each submenu.
Event Menu Example
In this example:
The users listed in the following table would see the event context menus shown in the fourth column.
User Primary User Group Subgroups Context Menu
User A Group A None Items from Menu A only:
Event Menu UserA
User B Group B None Items from Menu B only:
Event Menu UserA
User C Group C None Items from Operators:
Event Menu UserC
User D Group A Group B Items from Menu A above the separator and from Menu B below the separator, with no duplicates:
Event Menu UserD
User E Group A Group B and Group C Items from Menu above the separator and from Menu B and Operators below the separator, with no duplicates:
Event Menu UserE
(Device Info appears only once, items are sorted alphabetically).
Admin Administrators None Items from Administrators only:
Event Menu Admin
However, when configuring event menus, Admin would see all menus.
Diagram Menus
Unlike event and topology menus, the items in diagram menus are not combined based on subgroups. Diagrams do not automatically have menus. Instead, you can optionally add individual menus to widgets when configuring diagrams.
When configuring diagrams:
When viewing diagrams:
This applies even for users in groups whose role has the SUPER permission.
Diagram Menu Example
In this example:
The users listed in the following table would see the diagram context menus shown in the widget columns.
Users Primary User Group Subgroups Widget A Widget B Widget C
User A Group A None Items from Menu A:
Diagram Menu UserA
No actions:
Diagram Menu No Actions
No actions:
User B Group B None No actions:
Items from Menu B:
Diagram Menu UserB
No actions:
User C Group C None Items from Menu A:
Diagram Menu UserA
Items from Menu B:
Diagram Menu UserB
All items from Root:
Diagram Menu UserC
User D Group A Group B Items from Menu A:
Diagram Menu UserA
Items from Menu B:
Diagram Menu UserB
No actions:
User E Group A Groups B and Group C Items from Menu A:
Diagram Menu UserA
Items from Menu B:
Diagram Menu UserB
Diagram Menu UserC
