About Data Management
The Data Management module enables you to manage data fetched from multiple source applications into Construction and Engineering Intelligence.
As a Construction and Engineering Intelligence administrator, use the Data Management module to:
- Set up new connections with data sources such as Procore and Autodesk.
- View status of ingestion runs.
- Run on-demand data ingestion for a connection.
If your organization has purchased Construction and Engineering Analytics module, you can configure the following data sources:
- P6 EPPM cloud service
- Primavera Unifier cloud service
