Navigation Overview
The Home page of Construction and Engineering Intelligence displays the following menu and options.
This image is a graphical representation of the text the following table.
Menu / Option Description
"" Navigation Menu Select to expand or collapse the Navigator pane.
" " Help
The Help menu displays the following options:
  • Oracle Help Center: Select this option to access all guides in the Construction and Engineering Intelligence library.
  • Training: Select this option to access training resources available for Construction and Engineering Intelligence.
  • Support: Select this option if you need information on how to contact Oracle Support.
  • About: View the product version and build information of Construction and Engineering Intelligence.
1
Displays the initials of the signed-in user.
Select this option to sign out of the application.
2
Navigator
The Navigator displays the modules you can access based on your role and the modules your organization has purchased.
  • Overview: This is the main landing page.
  • Safety: Select this option to access the safety module.
  • Analytics: Select this option to connect, build, and view visualizations in Oracle Analytics Cloud. This module is displayed only if your organization has purchased the license for Construction and Engineering Analytics.
  • Administration: This option is available only if you are an administrator for Construction and Engineering Intelligence. The following options display under Administration:
    • Data Management: Select this option to set up and manage data sources.
    • User Management: Select this option to set up and manage users.
3 The selected module page is displayed. You can select the tiles displayed on the page to navigate within the selected module.
Navigating within the Application
You can navigate within the application using either the Navigator or the tiles on the page.
Using the Navigator:
  1. Click the " "Navigation Menu to display the Navigator pane.
  2. In the Navigator pane, select a module.
Examples:
  • To access the Administration module: From the Navigation Menu, select Administration.
  • To access the Analytics module: From the Navigation Menu, select Analytics. A new tab opens with Oracle Analytics Cloud.
  • To access the Benchmarks dashboard in the Safety module: From the Navigation Menu pane, select Safety, then select Benchmarks.
Using tiles
From the Overview page or from any of the module pages, select the tiles displayed on the pane.
Examples:
  • To select the Administration module: From the Overview page, select the Administration tile.
  • To select the Analytics module: From the Overview page, select the Analytics tile. A new tab opens with Oracle Analytics Cloud .
  • To access the Benchmarks dashboard in the Safety module: From the Overview page, select the Safety tile, then select the Benchmarks tile.
