Running an Ingestion Manually To run the ingestion immediately: From the Navigation Menu, select Administration and then select Data Management. On the Data Management page, click the Action Menu for a specific data source, and select Ingestion. On the Ingestion page, click Run. For P6 data source, you can choose Run On-Demand to refresh the data for the Activity On-Demand subject area in between schedule ingestions. In the Run a new Ingestion? dialog box, click Run to reconfirm. Select Cancel if you want to discontinue the configuration setup. The ingestion run will be added to the queue. Note:Publication services must run in the data source prior to any changes being captured by the ingestion process.
