About This Guide
This guide describes the operating systems and browsers that are supported with Construction and Engineering Intelligence.
Audience
This guide is intended for anyone using Construction and Engineering Intelligence.
Conventions
The following text conventions are used in this document.
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
