About This Guide
Provides details on out-of-the-box data visualizations delivered using Construction and Engineering Analytics.
Audience
This guide is intended for business analysts or database analysts who want to create data visualizations using Construction and Engineering Analytics.
Conventions
The following text conventions are used in this document.
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
