Aconex - User Project Organization
Description: The data displayed in the User, Project, Organization subject area, and in any out-of-the-box or custom dashboard is based on the projects that you have access in Aconex.
Use the User, Project, Organization subject area to discover information such as, (but not limited to):
  • identify owner and partner organizations within projects
  • identify the role of each organization in each project
  • identify projects and their corresponding owner and partner organizations by geographical locations
  • count of organizations (owner and participant orgs) involved in a given project
  • count of all projects that a specific organization is involved in (as an owning organization or a participant organization)
  • count of all users involved in all those projects that the logged in user is also associated with
Subject Area: Aconex - User, Project, Organization
Folder SubFolder Field Name Dimension/ Fact Description
User General - (User)
User General - (User) User Id Dimension The unique user ID of the Aconex user.
User General - (User) User Title Dimension The title prefix usually used to address the user.
User General - (User) Given Name Dimension The user's first name.
User General - (User) Middle Name Dimension The user's middle name.
User General - (User) Family Name Dimension The user's last name.
User General - (User) Division Name Dimension The division in the organization to which the user belongs to. For example, Project Management.
User General - (User) Job Title Dimension The user's position, role, or designation in the organization.
User General - (User) Job Function Dimension The function or department to which the user belongs to in the organization.
User General - (User) User Type Dimension Indicates if the user is a registered member or a Guest in Aconex. Possible values - MEMBER, GUEST
User Location - (User)
User Location - (User) User Address 1 Dimension The user's street address.
User Location - (User) User Address 2 Dimension The user's street address.
User Location - (User) Suburb Dimension The suburb or city the user resides in.
User Location - (User) State Dimension The State where the user resides.
User Location - (User) Country Dimension The user's country of residence.
User Location - (User) Postcode Dimension The zip code or the pin code associated with the user's residence.
Project General - (Project)
Project General - (Project) Project Id Dimension The unique project ID the user has access to.
Project General - (Project) Project Short Name Dimension The short name which is commonly used to refer to the project.
Project General - (Project) Project Name Dimension Displays a list of all project(s) that the logged in user has access to in Aconex.
Project General - (Project) Project Type Dimension The type of project.
Project General - (Project) Project Value Dimension The total value of the project in preferred currency.
Project General - (Project) Project Code Dimension A unique project code associated with the project.
Project General - (Project) Project Description Dimension A short description about the project.
Project General - (Project) Project Owner/Participant Dimension Indicates whether an organization owns the project or is a partner organization participating in the project.
Project General - (Project) Project Start Date Dimension The project begin date.
Project General - (Project) Estimated Completion Date Dimension The date when the project is estimated to be completed.
Project General - (Project) Fax Area Code Dimension The fax STD (Subscriber Trunk Dialing) number for the project.
Project General - (Project) Fax Country Code Dimension The fax ISD (International Subscriber Dialing) code of the project.
Project General - (Project) Fax Number Dimension The fax number for the project.
Project General - (Project) Phone Area Code Dimension The STD (Subscriber Trunk Dialing) phone number for the project.
Project General - (Project) Phone Country Code Dimension The ISD (International Subscriber Dialing) code of the project.
Project General - (Project) Phone Number Dimension The phone number for the project.
Project General - (Project) Datasource Id Dimension The unique ID of the datasource.
Project Location - (Project)
Project Location - (Project) Address Line 1 Dimension The street address of the project.
Project Location - (Project) Address Line 2 Dimension The street address of the project.
Project Location - (Project) City Name Dimension The city where the project is located.
Project Location - (Project) State Name Dimension The state where the project is located.
Project Location - (Project) Country Name Dimension The country where the project is located.
Project Location - (Project) Postcode Dimension The postal code for the project location.
Organization General - (Organization)
Organization General - (Organization) Organization Id Dimension The unique ID of the organization in Aconex.
Organization General - (Organization) Organization Name Dimension The name of the organization.
Organization General - (Organization) Organization Code Dimension The code or abbreviation used for an organization in Aconex.
Organization General - (Organization) Trading Name Dimension The trading name associated with an organization.
Organization General - (Organization) Company Registration Number Dimension The unique registration number associated with the organization.
Organization General - (Organization) Organization Project Roles Dimension The role of the organization in a specific project.
Organization General - (Organization) My Organization Dimension The logged-in user's organization name.
Organization Location - (Organization)
Organization Location - (Organization) Postal Address 1 Dimension The street address of the organization.
Organization Location - (Organization) Postal Address 2 Dimension The street address of the organization.
Organization Location - (Organization) Suburb Dimension The suburb or locality where the organization resides.
Organization Location - (Organization) State Dimension The state where the organization resides.
Organization Location - (Organization) Country Dimension The country of residence of the organization.
Organization Location - (Organization) Post Code Dimension The zip code or postal code of the organization.
Organization Location - (Organization) Email Address Dimension The organization's email address for general correspondence.
Organization Location - (Organization) Fax Dimension The fax number of the organization.
Organization Location - (Organization) Phone Dimension The phone number of the organization.
Organization Location - (Organization) Website Address Dimension The organization's website address.
Organization Location - (Organization) Delivery Address 1 Dimension The address of the organization
Organization Location - (Organization) Delivery Address 2 Dimension The address of the organization.
Organization Location - (Organization) Delivery Suburb Dimension The suburb where the organization's delivery address is located.
Organization Location - (Organization) Delivery State Dimension The geographical state where organization's delivery address is located.
Organization Location - (Organization) Delivery Country Dimension The country where the organization's delivery address is located.
Organization Location - (Organization) Delivery Zip Code Dimension The zip code or postal code of the organization's delivery address.
Fact - Aconex User Project Organization Fact - Aconex User Project Organization
Fact - Aconex User Project Organization Fact - Aconex User Project Organization # of Organization Fact
The total number of organizations on project(s) that logged in user has access to.
Fact - Aconex User Project Organization Fact - Aconex User Project Organization # of Projects Fact
The total number of projects the logged in user has access to.
Fact - Aconex User Project Organization Fact - Aconex User Project Organization # of Users Fact
The total number of users (members + guests) on project(s) that logged in user has access to.
