P6 - Resource Utilization / Primavera - Resource Utilization
Description: Use this subject area to analyze resource utilization details including actual, available, planned, remaining, at completion, and resource limit units.
| Folder | Subfolder | Field Name | Dimension/ Fact / Lookup | Description | Values Derived From / Calculated By |
| Fact - Primavera - Resource Utilization | Metrics | Metrics | |||
| Fact - Primavera - Resource Utilization | Metrics | # Of Resources | Fact | # Of Resources | count(distinct Fact_W_RESOURCE_LIMIT_F_Resource_Limit.RESOURCE_WID) |
| Fact - Primavera - Resource Utilization | Usage/Capacity | Usage/Capacity | |||
| Fact - Primavera - Resource Utilization | Usage/Capacity | Actual Units | Fact | The actual number of units incurred | Value Derived From : Fact_W_RESOURCE_LIMIT_F_Resource_Limit.ACTUAL_UNITS |
| Fact - Primavera - Resource Utilization | Usage/Capacity | At Completion Units | Fact | The sum of the actual units and remaining units for the resource assignment on the activity. Calculated as Actual Units plus Remaining Units. | P6Core."Fact - Resource Utilization"."Actual Units" + "P6Core"."Fact - Resource Utilization"."Remaining Units" |
| Fact - Primavera - Resource Utilization | Usage/Capacity | Available Units | Fact | Available Units | Value Derived From : Fact_W_RESOURCE_LIMIT_F_Resource_Limit.AVAILABLE_UNITS |
| Fact - Primavera - Resource Utilization | Usage/Capacity | Limit | Fact | Limit | Value Derived From : Fact_W_RESOURCE_LIMIT_F_Resource_Limit.LIMIT |
| Fact - Primavera - Resource Utilization | Usage/Capacity | Planned Units | Fact | The planned units of work for the resource assignment on the activity. | Value Derived From : Fact_W_RESOURCE_LIMIT_F_Resource_Limit.PLANNED_UNITS |
| Fact - Primavera - Resource Utilization | Usage/Capacity | Remaining Units | Fact | The remaining units of work to be performed by the resource on the activity. Calculated as Planned Units minus Actual Units. | Value Derived From : Fact_W_RESOURCE_LIMIT_F_Resource_Limit.REMAINING_UNITS |
