About This Guide
Provides detailed field-level information and dimensions for each subject area delivered in Construction and Engineering Analytics.
Conventions
The following text conventions are used in this document.
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
