5 Advanced Identity Management Tasks
The following task cannot be performed in Primavera Administration:
  • Users resetting their own password
To perform this task (and only this task), you will need to use the identity domain application directly. Oracle Customer Support will not be able to provide support if you use the identity domain for any other task.
Users Changing a Password
Users can log in to the identity domain to change their password. The new password must comply with the relevant password policy.
To change a password:
  1. From the Primavera Portal, log in to the identity domain application with your user name and password.
  2. Click Change My Password.
  3. In the Old Password field, enter your current password.
  4. In the New Password field, enter your new password.
  5. In the Confirm New Password field, re-enter your new password.
  6. Click Submit.
Wait five minutes before logging in to an account after you have changed a password.
