Customize the data date line
You can customize the data date line in the Activities and Tracking windows.
  1. With the Activities window active, choose View, Bars. You can also click the Layout Options bar and choose Bars. With the Tracking window active, display the layout, then choose View, Bars. You can also click the Display Options bar (in the right pane) in the Top Layout window and choose Top Layout Options, Bars.
  2. Click Options.
  3. Click the Data Date tab.
  4. To change the style for your data date line, select a style from the drop down list. The line can be solid, or contain dashes and dots. To change the thickness of your data date line, select a value between 1 and 10 pixels. This option is only available when the solid line is selected as the style. If your line style is something other than the solid line and you increase the size to a number greater than one, the bar style will switch to a solid line. To change the color of your data date line, choose a color from the color palette.
  5. Click OK. To view your changes without closing this dialog box, click Apply.
