Zoom in and out of a timescaled layout
Zooming in on a timescaled layout (Gantt Chart, spreadsheet, or profile), displays a shorter range of time using smaller time intervals, for example, zooming from a quarterly to monthly to weekly display.
  • To view a smaller timeperiod at a greater level of detail, click "" on the Display toolbar, or position the mouse pointer in the layout, then right-click and choose Zoom In.
Zooming out displays a longer range of time using larger time intervals, for example, zooming from a weekly to monthly to quarterly display.
  • To view a larger timeperiod at a lesser level of detail, click "" on the Display toolbar, or position the mouse pointer in the layout, then right-click and choose Zoom Out.
    • When the Top and Bottom Layout windows both display a timescaled layout, zooming in or out changes the timescale in both windows.
    • The right-click zoom options are not available in the Gantt Chart.
