Add a role
- Choose Enterprise, Roles.
- Click
on the Edit toolbar or choose Edit, Add.
- Click the General tab, then type a unique ID for the role.
- Type the role's name.
- Click Modify to type a description of the role's responsibilities in an HTML editor. In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
