Add projects to a portfolio
  1. Choose Enterprise, Project Portfolios.
  2. Select the portfolio to which you want to add projects.
  3. Click the Projects tab.
  4. Click Assign.
  5. Select the projects you want to add. To add multiple projects, hold down the Ctrl key, then click each project you want to add to the portfolio. All projects the user has access to are listed, not just those in the current portfolio.
  6. Click Assign.
  7. Click Close.
    • To add a project, you must have edit rights to the selected portfolio.
    • You cannot add projects to a filtered portfolio. Filtered portfolios select the projects on the basis of criteria specified in their filter.
