Assign a calendar to an activity
  1. Choose Project, Activities.
  2. Select the activity whose calendar you want to define.
  3. Display Activity Details, then click the General tab.
  4. In the Activity Calendar field, click "".
  5. Choose the calendar that you want to assign to the selected activity, then click the Select button.
Tip:
To choose whether to display global or project calendars in the Select Activity Calendar dialog box, click the Display Options bar.
