Assign activity codes and values to activities
- Choose Project, Activities, then select the activity to which you want to assign a code and value.
- Display Activity Details, then click the Codes tab.
- Click Assign.
- If an applicable activity code value does not exist, then proceed as follows to create one. Otherwise, go to the next step.
Click the New icon
, type the new value and its description, and click OK. Then go to the next step to select and assign it to the selected activity. - Select the activity code value you want to assign. You can only assign one value per code.
- Click Assign, then click Close.
- If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
- You can assign global activity codes to any activity. You can only assign project level activity codes to activities in the project where the codes were created.
- You can only assign EPS-level activity codes that have been assigned to the selected activity's project.
- Any EPS-level activity code associated with an inaccessible EPS node will appear under the "No EPS ID" node in the Assign Activity Codes dialog box.
- The New icon
is disabled if no code band is selected or if you do not have security to edit the selected type of activity code (global, EPS, or project).
