Assign a tracking layout to a threshold
You can assign default tracking layouts to thresholds and their issues. This enables you to use the Issue Navigator to quickly open the tracking layout that best displays the threshold's issue details.
- Choose Project, Thresholds.
- Select the threshold, then click the General tab.
- In the Tracking Layout field, click
. Select the tracking layout you want to assign, then click the Select button.
