Assign color to project-level activity code value
Colors assigned to activity code values are used only in Visualizer drawings.
This procedure assumes you have already created an activity code value for which you want to assign a color.
  1. Choose Enterprise, Activity Codes.
  2. Choose Project.
  3. Select the activity code with the activity code value for which you want to assign a color.
  4. Double-click the cell under the Color column for the applicable activity code value. This launches the Color dialog box. When you complete that dialog box, click OK.
  5. Click Close.
    • The color of each new activity code value defaults to blue.
    • The Color column is disabled for Project activity Codes if you do not have the "Edit Project Activity Codes" project privilege.
    • The Color column is disabled for secure codes if you do not have the "Edit Secure Codes" global privilege.
    • To remove color from an activity code value, launch the Color dialog box and assign the color white.
